跳转到主内容
Repair information for the Samsung Chromebook Plus. Released in February of 2017. Model number: XE513C24.
20 个问题 查看全部
Replace keyboard on Samsung Chromebook PRO/Plus
I recently spilled liquid on my Chromebook Pro and some of the keys are no longer working. I tried to remove the keys to see if any residue was causing them to not work but to no avail. Is there a DIY to replacing the entire keyboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
This is going to take replacing the entire palmrest, keyboard, track pad assembly for the most painless repair. The assembly usually runs between $50-80 and the repair should take about 30min if you're comfortable with laptop and phone repairs.
这个答案有帮助吗?
得分 1
添加一条评论
You’re better off sending it off to Samsung to deal with this one. Also, isn’t this chromebook quite new? You should check to see if it is still under warranty.
这个答案有帮助吗?
得分 0
添加一条评论
Unfortunately it's gen 1 purchased right after it's release date and out of warranty. Thanks for the suggestion though.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joe Dellava 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,084
