跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
iPhone 6 won't turn on but charge
Hey,
I tried to fix this iPhone 6 but it here is what it already checked for:
  1. It’s not turning on at all
  2. No charging sound when plugged in
  3. The device charges as it takes 0.5amps from the charger
  4. I already checked the battery it’s fine
I thought a change of the Tristar IC would fix it but I guess due to the symptoms, this won’t be the case. What else can I check for or try?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
What is the history of the device; was it dropped, repaired or came into contact with water prior to this failure? Is the phone charged with a cheap dollar-store charger or an Apple original or MFi certified charger?
If you’ve already ruled out the battery, then consider trying a replacement Lightning port. However, with the symptoms it shows, I would suspect a logic board issue, which will require a micro-soldering repair.
这个答案有帮助吗?
得分 1
1条评论:
@refectio cant say lot about its history. There is no water damage as far as I can say that neither was it repaired before. Bad charger could be. Any ideas on what to test for/replace on the Logicboard? Sure it needs microsoldering.
完成的
添加一条评论
添加你的答案
andruchs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 124
