跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Error code 4013 on attempt to restore?
My 6 randomly stopped working one day, I went home to connect to ITunes and got an error code 4013. I have went into DFU, it does not work. Most of the time when i restore the phone the loading circle appears for 1 second, then the phone restarts. Would anyone know why?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Error 4013 can be caused by data corruption in the NAND or by other hardware failures. The data corruption issue can happen when the memory is nearly full.
What do you mean when you say DFU did not work? Is it that you could not get into DFU or that a DFU restore failed with an Error 4013 as well?
The device can probably be repaired by via a micro-soldering repair but the data may be lost forever.
这个答案有帮助吗?
得分 4
2条评论:
What I meant by DFU did not work is I tried to restore under DFU mode but the restore failed.
完成的
In every instance I have had with 4013 in iphone 6 and 6 plus... it required removing NAND and reprogramming it or replacing it. You have already lost your data and the repair is not very economical anymore due to the cost of repair vs. iphone 6 value working 100%.
完成的
添加一条评论
It seems some internal hardware failure still i would suggest your to charge iphone for 1 hour and then try to restore. And if iphone start then try to reset all setting.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bryant 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 97
