跳转到主内容
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 个问题 查看全部
Why is my screen has a high contrast even when turning it down?
I just saved this old mac from being thrown into the garbage by my college surplus store and fixed it up. However, every time I boot it up, it has a whitish screen and then I have to put it to sleep for a few minutes and it will look fine. Is there an issue with the lcd or video card?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sadly your logic board has a problem. I suspect one or more of the caps or solder joints in the GPU logic has degraded so it needs a bit of time to warm up to work.
Your logic board has the GPU chip mounted onto the main logic board it doesn’t have the MXM GPU daughter board design.
I would leave things alone and live with it. If you really want to fix this it will take someone with good board level diagnostic skills.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Bau Pham 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 49
