New SSD in mid 2012 MBP won’t load OS X
A couple days ago my hard drive died. I figured it was time for an upgrade and saw that just about everyone recommends SSDs and figured it couldn’t be too hard to replace.
Well, I bought a Samsung 860 EVO, installed it, erased and reformatted it to Mac OS (Extended), and then started the OS X install process, which is where everything fell apart. It started an install of Yosemite, which I thought was weird because I’m fully updated to Mojave, with an install time of 16 hours. Which seemed excessive but I didn’t question it. I went to bed with 14 hours left and woke up maybe 8 hours later to see a flashing ? folder. I figured something had gone wrong during the install, it happens, so I erased the drive and started over. And then it happened again. I’m currently on my third try, with 20 hours left on the estimated time (it was 14 last night when I went to bed, not sure why it’s so much longer now).
Is there something I’m missing or forgot to do? I’ve read mid 2012 MBPs have fragile hard drive cables, so could this be a sign that mine is faulty? The laptop definitely recognizes my new SSD and I was able to erase/partition/select it for the install but I guess it could still be bad. I’ve also had problems ever since I installed a new battery from iFixit a couple weeks ago where if I leave the MBP alone for too long it shuts itself off, but that seems to be limited to when I’m not plugged into the charger, so it shouldn’t have happened during my install attempts. I’ve reinstalled the old battery for this new attempt just in case though.
Thanks for any help you may have!
