跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 个问题 查看全部
New MacBook Pro battery has only 13 mAh to give
Short version: After a few weeks of usage this new battry has a Full Charge Capacity of only 13 mAh. A shutdown is a matter of seconds. Resetting SMC and nvram/pram doesn’t seem to change anything. Old battery is working well.
Long version: Bought this new battery a month ago and it worked beautiful the first two weeks. I don’t have the exact data anymore, but it was a little above the design capacity after first charge-recharge (~ 7000 mAh). Did the thermal paste replacement at the same time. When the laptop already open and that iFixit pro toolkit is begging for more. It’s hard to resist, sorry.
Everything worked well for the first two weeks. Not sure if it has anything to do with the current problem, but I decided to open this MacBook Pro for a second time to replace the thermal paste with graphite pads (advice: don’t do that. It’s a little worse than thermal paste). Everything went well, again, and as I forgot the first time to clear pram and SMC reset, did it this time in combination with a new ‘calibration’. Left it after a full charge drain the battery. Plugged the charger in after two days and the led changed to green within minutes and shows a 100% charge.
Research after a really, really quick low battery shutdown showed the Full Charge Capacity is 13mAh. No key combination, drainage or resting outside the laptop does it change to any higher value afterward.
Thinking the fiddling with the logic board had something to do with this I put the old battery back which is working great for the last week.
Today I tried the new battery again and nope, still like Friday the thirteenth.
Is this some calibration issue or a textbook example of a dead battery?
Note: Battery was outside laptop when repairing. No chance of shortcut or anything I believe.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
To put it simply, you probably got a low quality battery. I reccomend you get a new battery from iFixit because they guarantee their batteries will perform excellently under their limited 1 year warranty; I have a battery from iFixit in my school issued MacBook Pro and it works fabulously.
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Battery
Also, I apologize for not getting to this one sooner, it fell thru the cracks on my end. Hope this helps!
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Battery图片
产品
$89.99
这个答案有帮助吗?
得分 1
1条评论:
First, sorry for this way too late a reply.
Thanks! You are right.
I tried to revive the battery a few weeks ago with all kinds of reset, calibrating and charging. Still 13mAh, no more, no less.
I bought another one and this one is running fine for a week now.
(Funny fact: the first battery from 2011 is still working all right with about 2 hr of battery life after 8 years use)
完成的
添加一条评论
添加你的答案
Ton Brands 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 143
