跳转到主内容
Repair guides and support for your LG TV.
1343 个问题 查看全部
50LF6000-UB - Screen flickers off and on constantly
Trying to help wife’s friend with her 2-1/2 year-old, 50” LG television… TV powers on and seems to work, with sound, etc. The screen constantly flickers off and on, regardless of the input or any changes in the menu. All of the LEDs flash off and on together in complete synchronization, every 1300ms. While they are on, the screen is visible and you can see the menu and other elements very clearly. Audio works all of the time.
Already tried: resetting TV to "initial settings," turning off "Energy Saver" mode, and I have also replaced the main power supply board with a new board, with no change or improvement. Measured standby voltage at 3.2V.
What else should I try? Are there more multimeter tests that would be helpful? Is it worth putting more $$ into this device?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Just noting that this TV did have a burned out, bad LED on one of the strips. I very carefully replaced the entire strip, and the backlight is now strong/steady.
Unfortunately, during the disassembly/reassembly process, something must’ve gone wrong because there is no picture onscreen anymore, at all. Before, when the backlights would blink on, you could see the LG menu and everything, very clear—no there is nothing onscreen, just a dull, dark glow. (And, audio still works…)
Anyone have a suggestion at this point, please? HELP!
完成的
The two ribbon cables from the T-con board into the screen are not aligning correctly. When disassembling, you would have disconnected one side of these small cables (2 of them). I found the same problem you did when I replaced all my LED back-lights and re-assembled the TV. The cables can be finicky. Reset the tv by holding the power button down for 15 to 20 seconds and you should have a picture. You just have to make sure the ribbon cables are seated in the the tiny connection bar correctly and reset the tv. I hope that helps.
完成的
添加一条评论
2个答案
Loose HDMI cable at the back or dead back light
这个答案有帮助吗?
得分 0
1条评论:
There was a bad LED in the backlight, which I fixed. Now, there's no picture on screen, at all...
完成的
添加一条评论
i have same pulled all cable off left one to control board LEDs flash off and on
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ctgriffi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 10
总计 2,059
