跳转到主内容
加入维修社区 - 创建账户
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
TouchID won't work after screen replacement
Hey guys I was repairing a friends iPhone 6 Plus screen and while removing the LCD shield that has the home button link cable running through it, I pierced that cable and the home button/touchID didn’t work. So I ordered a new LCD backplate with a cable pre-installed and just put the new shield on today.
After installing the new shield, the home button works but the TouchID does not. It doesn’t say anything like “TouchID not recognized” It just doesn’t do anything when you try to set up a new finger print. Any fix to this?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@northsaad Are you aware that when you replace an iPhone’s home button that Touch ID will no longer function? That may be the issue you may be running into if you are not aware of the above.
完成的
@ajcooke01 Yes, but I did not replace the home button because that works fine. I replaced the home button link cable that runs along the LCD shield.
完成的
添加一条评论
1个答案
已选择的解决方案
Do a thorough visual inspection of the new Link Flex (corners and connectors on either end) and also look at the Home Button itself as you may have damaged that as well. It really doesn’t take much to make the Touch ID fail. Use a jewelers loupe to get a really close look.
If everything looks good, you may have a defective Link flex. Sometimes the issue can also be on the soldered connections for the connector on the flex.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Saad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 71
