跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
Procedure to install I D V D application in the laptop
I download exercise videos from the youtube, My backup procedure is no longer with I Cloud.My hard disc capacity is 250 gb. To burn in to a DVD I need to convert for the D.V.D format I downloaded Handbrake, to convert it in to a D.V.D format the options are many and it is confusing and I tried 2 options both flopped unable to view only sound track could be heard.Free options are only a limited version,APPLE chooses the option to fleece the customers I am expressing it with regrets. Thank you Narayanan Lakshmanan INDIA
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Sooo... are you trying to burn a video to a disc? Is that what you need help with?
完成的
Yes I need guidance
完成的
添加一条评论
1个答案
最有帮助的答案
If you have the video files in .mp4 file format you can use the instructions at the link below to create a DVD you could play in your e.x. DVD player or Xbox 360/One. However, for the Mac you have listed that you have you will need a USB-C to USB-A adapter and an Apple USB SuperDrive to make a DVD as Apple has stopped making Macs with SuperDrives internally since about October of 2012 (oddly specific).
https://support.apple.com/guide/mac-help...
If your files are not in .mp4 file format and you wish to convert the videos to .mp4 file format you can use the online converter here. I have used this site for converting video files myself and I can guarantee that it is safe to use. Just don’t stray onto the popup ads and use common sense.
这个答案有帮助吗?
得分 1
4条评论:
Online version is a cumbersome process please suggest any desktop version which is a free download without any conditions attached.Thank you
完成的
There is currently no good way to do this without using an online converter to convert your video files to .mp4 . As long as you know how to use the online converter I linked to then that is your best free option at this time. All the other software I found is either located on a sketchy website or a paid software.
完成的
Thank you I will pursue it
完成的
You're very welcome! If you did find this answer acceptable please mark it as correct so we can tidy up unaccepted questions.
完成的
添加一条评论
添加你的答案
NARAYANAN LAKSHMANAN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 138
