跳转到主内容
The Asus ROG Strix GL702VM-BHI7N09 is a gaming computer released by Asus in January 2017. It can be identified by the serial number on the bottom of the keyboard.
22 个问题 查看全部
What's wrong with the GPU?
Recently, gaming particularly “heavy” games, it blue screens or freezes with blocks/stripes of green/white/purple.
I’ve tried a fresh install of Windows, a different drive that I know is fine, different NVIDIA drivers. So I’ve narrowed it down to the GPU.
I’ve done some runs of Furmark, and each time, when it gets to >75C it usually blue screens or freezes with blocks/stripes of green/white/purple, and if it doesn’t do that on its own, a reasonable tap on the keyboard where the GPU chip is causes it.
Is this a sign that it needs BGA reballing by a repair shop, or is it a more serious less-repairable issue?
Thanks in advance for any help :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Joe McKinnon try some GPU throttling and see if it makes a difference. Root cause for this is poor airflow to keep things cool. https://rog.asus.com/forum/showthread.ph...
完成的
添加一条评论
1个答案
最有帮助的答案
Yep, “Recently, gaming particularly “heavy” games, it blue screens or freezes with blocks/stripes of green/white/purple.” thats a sign of a dying/deadGPU. If the GPU in this machine is modular and can be replaced it is a simple and relatively inexpensive fix if you have the right part. However, if the GPU is soldered to the motherboard that would require a motherboard replacement which is by far not the easiest thing to replace and it will be costly.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joe McKinnon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 152
