跳转到主内容
The first 8 inch Android tablet by Samsung.
50 个问题 查看全部
Tablet not powering on, next steps?
Hi there,
the tablet does not power up, I tried pressing the suggested button combinations.
By measuring the battery leads I can see 3.69V.
What are the next steps? I would like to avoid buying a battery if battery is fine, same goes for the powering circuit and motherboard.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
8条评论:
Hi @hyklamin ,
Does it turn on with the charger connected and switched on?
完成的
The tablet cannot be turned on. It is written in the question.
完成的
Hi @hyklamin ,
OK but you only said that "the tablet does not power up, I tried pressing the suggested button combinations." and "By measuring the battery leads I can see 3.69V."
Nowhere is mentioned that you tried powering on with the charger.
All what you said could have been done on the battery only
How long did you hold the Home, Power and Vol. up buttons for? it may take a bit longer than you think.
完成的
Long enough. I am asking how to detect which component is malfunctioning, we are beyond the basic troubleshooting steps.
完成的
Hi @hyklamin ,
Since I don't know what you've tried,try the following,
Disconnect the battery from the systemboard for a few minutes, then reconnect it and then connect the charger to the tablet and leave it for a while to see if the tablet starts to charge at least.
完成的
显示更多的3条评论
添加一条评论
1个答案
Have you tried taking the battery out, holding the power button for 20-30 seconds, then releasing and putting the battery back in? That usually fixes my phone when that happens, so might be of help.
这个答案有帮助吗?
得分 0
2条评论:
@dud1f3r if you take the battery out there is no point to hold a button, as there is literally no electricity going anywhere on the circuits
完成的
It flushes the capacitors or something along those lines. Try it and see what happens, it works for me so might help you out. Imma be real with you though, I have no clue how it does but it does sometimes, so it's worth a shot.
完成的
添加一条评论
添加你的答案
Yklamin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 69
