跳转到主内容
Why is my screen going black after boot-up? Its like my GUI is funky.
My Dell M64 screen goes black right after I log into windows. I have to hard start several times until it catches. I installed a GUI contol to lower my stats, but it still does it sometimes. Wierd stuff man.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
does an external monitor give you an image?
完成的
This is the process...
Laptop is on docking station. Or plugged in charging.
Plugged into external monitor.
Turn Laptop on. Goes throught boot process.
Log in with password.
After about a minute my screen goes black. Both of them.
Now...
Laptop off the docking station and power charger cord. Running on battery only. There are no issues with black screen.
If i wait for everything to load and activate the GUI speed lower and plug it back in or connect it to docking station. No problems.
So, i only have these problems when it is plugged in to charge battery or connected to docking.
Hope this is understandable. Thanks
完成的
添加一条评论
1个答案
已选择的解决方案
have you tried another AC? if draws a lot of power because is defective that might be the reason.
can you remove the hard disk and battery, turn of the pc and after the logo press the F2 key.
this gets you into what is called the “Bios”.
Leave on for 10 minutes or more and see if the screens gets black.
if it does turn it off and back again this time press the F12 and the F5 for diagnostics.
Run a full diagnostics. If it is good then and if you can get a new hard disk and install the OS, nothing else.
After you finish the installation turn it on and let on for 10 or more minutes. see what happens.
As a technician i could do more trouble shooting but that requires that i have the pc with me.
i am not trying to get any business from you. Here on ifixit i give free advice that might help solve the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
William R Darrow 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 89
