跳转到主内容
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
197 个问题 查看全部
new ssd and os install
Don’t know if this is where I should ask…. but if I go ahead and put a new empty ssd in my late 2014 mac mini, can I just re-install OS (mojave at this point, with mac OS utilites? (command & r on boot. ) I don’t want to clone it externally as it has too much info and not enough room on new drive. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Sure, you will need to create a bootable Mojave installer with the guide below. Then you should just be able to hold option on startup and choose that bootable USB you made with the guide.
http://osxdaily.com/2018/09/26/make-maco...
这个答案有帮助吗?
得分 0
2条评论:
Thanks so much Aaron! Going to give it a go now!
完成的
@rob755 No problem! Let us know how it goes.
完成的
添加一条评论
添加你的答案
Robert Hamilton 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 12
总计 2,023
