跳转到主内容
Shark Navigator Lift-Away (NV352) is a type of vacuum that functions on both hardwood and carpet with a lift-away feature. The NV352 includes several cleaning attachments. The vacuum was released in 2008 and is often referred to as the Shark Navigator Lift-Away.
10 个问题 查看全部
Why does my rotating brush stop spinning when it is in use..
I replaced belt, rotating brush on the vacuum. It starts rotating again after I put vacuum in upright position and back until vacuum position. It runs for a short period then stops rotating . It does this continuously for as long I’m using the vacuum.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If your Shark vacuum stops moving suddenly during use, see the Shark ION Robot R75 Stops Moving Unexpectedly problem page for possible problems and solutions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pick608 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 156
