跳转到主内容
Repair guides and support information for televisions manufactured by RCA.
181 个问题 查看全部
stuck on The "initial setup" screen
I have a 32" rca LED LCD HDTV
model# LED32B30RQ
Great t.v. but today it is stuck on
The "initial setup" screen and it sits off to the left side of t.v. (my right) and my remote nor the buttons on t.v. are useless for some reason ....please please help me
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
Hi @ dyanawebber.dw
Try a power reset.
Switch off the TV power outlet and disconnect the TV power cord from the outlet.
Press and hold the TV's Power button for 30 seconds and then release.
Reconnect the TV power cord to the power outlet and switch on the outlet.
Turn on the TV in the normal manner and check what happens next.
这个答案有帮助吗?
得分 3
3条评论:
Exactly what do you mean shut off the power outlet? I get the unplug it but its plugged into the wall
完成的
Hi @dyanwebber.dw
Apologies.
As I don't know your location or what type of power wall outlet you have, I go for the safe way first i.e. IF the power wall outlet has an on/off switch on the wall outlet itself (where I am that is normal for a power wall outlet) switch it off before removing the the TV power cord.
Obviously your wall outlets don't have an on/off switch and you just remove the TV cord from the outlet.
That can be done here also but it is safer if you turn off the power at the outlet so that you don't touch any "live pins" of the power plug if you pull it half out and accidentally touch them if you grab the plug with your fingers wrapped over the edge if you get what I mean.
完成的
Hi Ms. Dyan Webber,
You are absolutely correct in saying to turn off the power and remove the plug from outlet for about 60 seconds my way of doing it that helped me! God bless you Ma'am and thank you!
完成的
添加一条评论
You have a failed EEPROM on the signal (main) board. Location is U16. This eeprom is difficult to remove. In this case you can order a a main board ($75). You must be sure to get an exact replacement. I have repaired many of these. with eeprom replaced only ($15.00 plus labor). Thanks for asking, Matt of Martins TV Repair.
这个答案有帮助吗?
得分 0
添加一条评论
Im sorry to say but the ONLY WAY. You can get it back to tv… is if you have the remote.. If you lost the remote download the app on your phone that would make it a universal remote and you be able to cancel or continue the process. I turnt off the tv then unplugged it from the back and unplugged it for 30 mins and still nothing. I found my remote and pressed cancel and my tv back
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dyanawebber.dw 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 28
过去 30 天: 77
总计 9,322
