Keyboard and trackpad behave erratically
Hello!
i have a slight problem with my MacBook Pro early 2015. For some reason the keyboard strokes are not correctly registered by the OS. On the login screen typing either triggers the “can’t type here” sound or wrong letters / erratic movement occur. For example pressing the louder button usually first turns the sound down twice and then mutes the Mac. Also a trackpad click only triggers the secondary function. A normal click or tap is not possible.
This is already weird but I also checked the onscreen keyboard and there the right buttons are highlighted meaning that at least there I see full function . However, After connecting an external keyboard and typing a little bit the onscreen keyboard shows only weird signs when I type one the MacBooks keyboard
Sometimes the keyboard completely works for some time just to revert to the no-function a little later.
What did I try to fix it:
I already exchanged the cable that connects the trackpad to the logic board and cleared the nvram.
3条评论
Hi there, I have exactly the same problem with yours, with the same model. Are you able to resolve it in the end? I changed my trackpad cable too but issue still remains. :(
由 microCuts 完成的
@microcuts - Sounds like you need a new trackpad.
由 DanJ 完成的
In my case, the keyboard had a water damage.
由 a.kuchta 完成的
