跳转到主内容
加入维修社区 - 创建账户
The HP Pavilion dv6500 is an affordable multimedia notebook with a 15.4" screen , a stylish case, and a security fingerprint scanner.
Working charger won't power or charge laptop.
Have a DV6500 HP laptop with good battery and charger. Suddenly it will not charge or power up when charger is plugged in. When I charge the battery on another laptop and put in the defective one, the laptop will run fine. I have replaced the charger board but no success.
Any Ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thanks for the answer, but unfortunately that did not solve the issue. I’m thinking it may be a hardware issue in that it was charging the battery and then suddenly stopped. The charger has tested good, the battery is good and I have changed the charger board out. The computer works fine with a battery, unfortunately I cannot charge the battery or power the laptop with the charger.
完成的
添加一条评论
1个答案
最有帮助的答案
HI:
I would say you have a corrupted battery driver, did you know the battery needs a driver to charge.
Got to control panel and find device manager, Battery, uninstall the drivers and re boot with charger plugged in . Windows will be looking for a driver API, you may have to go to the internet to get the driver, install it and reset again.
I hope I understand your explanation and this works.
Good luck.
Alton
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
csand 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 8
总计 490
