跳转到主内容
Model A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
50 个问题 查看全部
iMac EMC2805 Logic Board Replacement
I have a 21.5” iMac Mid 2014 A1418 with logic Board 820-4668-A which is faulty.
Looking for any alternative logic board I can use which will work in this system.
Also one that can support upgradable memory and/or blade SSD supporting logic board.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Were you able to find an alternative compatible logicboard? Or were u stuck having to replace with the same one?
完成的
添加一条评论
1个答案
最有帮助的答案
I found a 1.4 GHz Logic Board that supports a blade style SSD on an external site (iFixit is sold out) but you are limited to 8 GB of RAM because it is soldered to the Logic Board. I did a pretty widespread search but found no compatible Logic Board that you can upgrade the RAM on. You will need to replace the display adhesive strips and I have included a link to buy them below too.
http://www.dvwarehouse.com/661-00148-App...
[关联产品丢失或禁用: IF173-005]
iMac Intel 21.5" EMC 2805 Logic Board Replacement
iMac Intel 21.5" EMC 2805 Blade SSD Replacement
iMac Intel 21.5" EMC 2805 Logic Board图片
指南
难度:
中等
iMac Intel 21.5" EMC 2805 Blade SSD图片
指南
难度:
中等
30 minutes - 1 hour
这个答案有帮助吗?
得分 2
4条评论:
Thankd for the answer is this model has any fixing issues on iMac cabin
完成的
Hold on! @ajcooke01 - The logic board you pointed to has fixed RAM and does not offer SSD support!
@rajiv8047 - Lets find a better board!
完成的
@danj you aren’t going to get much better then fixed RAM, the one I just updated the link to has SSD support.
完成的
添加一条评论
添加你的答案
Rajeev 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 181
