跳转到主内容
The Lenovo IdeaPad 300-17ISK is a 17-inch laptop which was released in October 2016. The Model number is 80QH008MUS.
My device won't power on
My model is actually the ideapad 320-15abr. My issue is it won’t power on unless I do the reset procedure by removing battery holding down power. I have to do this every time and only works some of the time. Last time I left it on and it was completely off two days later and will not power on. All diagnostic tests came back good.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
HI:
Going out on a limb here but I think your power supply is hooped.
Or failing or faulty. This could include the plug at the end or even the power plug at the laptop may be broken or faulty inside. If you can borrow another supply or even take the units to a friendly computer shop for a quick check.
This trouble could go all the way to your motherboard.
Have worked on hundreds of laptops but this is a strange one.
Good luck
AB
这个答案有帮助吗?
得分 0
添加一条评论
If your laptop is showing no signs of life and refuses to turn on, use this Lenovo IdeaPad U530 Touch Does Not Turn On problem page for possible causes and solutions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
chrisellis87 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 363
