跳转到主内容
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
197 个问题 查看全部
Wired Keyboard & Mouse not working.
Wired keyboard & Mouse not communicating, not able to log in. Performed PRAM & SMC resets, did not fix. Cursor stuck at the top left corner of screen, key strokes from keyboard do not register.
Wired mouse will light up when plugged into front or rear USB ports, cursor does not move.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Could be several things. Start with disconnecting the mouse and plug it straight into a USB port. Now you can independently test both the keyboard and mouse.
Next start up in Safe Mode by holding down the Shift key on start up. This will tell you if it is a software issue. Let us know your results.
UPDATE
I’m wondering if the keyboard problems have prevented complete resets. I’d start over, go through all of this to see if you can reset. If after all this we can look at running in depth hardware diagnostics.
First and foremost, keep in mind that sometimes a USB device itself can fail, which may have nothing to do with the Mac itself. This is particularly true with cheap low quality USB devices and cables. The easiest way to determine if the USB device itself is the problem versus the Mac USB port, is to try and use at least two different USB devices and switch their ports. If multiple USB devices are not working on a particular port, or all ports, then it’s obviously less likely to be a device issue, and more likely to be related to the Mac itself. And yes, this can apply to any and all Macs, whether a MacBook Pro, MacBook Air, MacBook, iMac, Mac Mini, or Mac Pro.
The Solution to No-Cause Random USB Failure on a Mac: Resetting SMC
So, you’re confident a USB port is the problem and not the device itself? The first thing you should do is reset the Mac SMC, a simple process which is slightly different depending on the Mac hardware.
You can learn how to reset the SMC on all Macs here in our detailed tutorial. For those with a MacBook, MacBook Pro, and MacBook Air, all you need to do is this:
  • Shut down the Mac and connect the power cable
  • Hold down Shift+Control+Option+Power concurrently for a few seconds, when the light on the power adapter blinks or changes colors you’ll know SMC reset is complete
  • Release all keys at the same time
  • Boot the MacBook Pro / Air by hitting the power button as is typical
The USB ports on the MacBook should now work just fine, which you can confirm by connecting the USB device as usual and checking to be sure that it works – if it’s still not working, try another USB port, and try another USB device.
Another Fix for USB Not Working: the NVRAM Reset
Sometimes resetting the NVRAM / PRAM on a Mac can help resolve the USB port failure as well, since NVRAM holds various data about keyboards, mouse, trackpad, and other USB components. Here is how you can perform the NVRAM reset on a Mac to see if this resolves the USB failure:
  • Restart the Mac, and immediately hold down Command + OPTION / ALT + P + R keys together – keep holding the keys down until you hear a sound and see the screen flash, it may take a few seconds
  • The Mac should make a chime sound again, then let it boot as usual
When the Mac boots back up again, USB should be working as usual.
If, after an SMC reset, and after an NVRAM reset, none of the USB ports are working, and no USB device is working, something else is likely up with the Mac.
Other Considerations for USB Not Working on a Mac
  • If a single USB port has failed but other USB ports are continuing to work on the Mac, even after an SMC reset, there may be an issue with that specific hardware USB port – you can either avoid using that USB port and instead use a USB hub for one of the other functioning ports, or you can have Apple run a hardware diagnostics test on the machine to determine if there is any hardware failure
  • If liquid has splashed on the Mac or the MacBook has contacted water, you will need to take immediate steps to power down and dry out the Mac for a chance to prevent permanent damage – liquid contact can destroy a Mac rather quickly, or damage certain hardware functionality, like USB
  • If some USB devices work on the Mac, but another USB device does not work, consider that the device may be incompatible with that particular Mac, the USB device may be failing or have failed, or, in some situations, the USB device may need specific hardware drivers from the manufacturer in order to work properly (typically the case with special use devices, high-end scanners, etc)
  • If there are firmware and OS X software updates available, install them onto the Mac. You can check this by going to the  Apple menu > App Store > Updates section – be sure to backup the Mac before installing any system software
Why USB may suddenly cease to work isn’t always obvious, but if all else is well and the USB failure happened out of the blue, the hardware SMC reset is almost always the solution. This exact scenario happened to me recently when I traveled with a MacBook Pro, where mysteriously many hardware functions on the Mac failed simultaneously, with all USB ports ceasing to work with any USB device, a Bluetooth Unavailable errorappeared, sleep failure, and fans spinning up like a jet engine with no apparent cause – all classic symptoms of something gone haywire with the System Management Controller, all easily resolved by the reset process outlined above and here. Of course, I’m an experienced Mac user so I knew this this, but given that many other Mac users out there are less familiar, this type of troubleshooting is always worth covering and sharing.
这个答案有帮助吗?
得分 2
3条评论:
I don't think the mouse or the keyboard are communicating to the unit. I have tried 3 MAC keyboards plugging into the 2 front USB and 3 rear USB ports. Also tried a wireless Microsoft keyboard. CAP lock, Scroll lock, Num lock do not register when pressed on the indicator lights of the keyboards. I have tried using wired mouse connecting to all USB ports front and rear. The red light comes on showing power, the cursor on the display is stuck in the upper left hand corner of the display. I tried holding shift key down while powering up the unit to start in safe mode. Nothing seems to have changed, I have performed the SMC reset since that doesn't require a command from the mouse or keyboard, just power button. I took 1 of the non functioning MAC keyboards and connected to Dell OptiPlex 7040, CAP, Scroll & Num lock worked and indicator lights also worked.
完成的
What everyone who THINKS they have the solution to this problem seems to forget is.... if you have no working usb ports on a mac pro you can't use a keyboard or mouse, so how do your solutions make any sense? one can't type anything, click anything or hold down any key combinations whilst rebooting! can't do SMC ,VRAM, PRAM, Safe boot, recovery mode nothing! any other worthwhile suggestions people?
完成的
gc I also have a PCI USB3 card in mine.
完成的
添加一条评论
添加你的答案
Richard Power 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 45
总计 30,644
