跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
LCD Flex Cable Reseating
If you are reseating the lcd flex cable after repair and you fiddle with it to get it back in can that cause any issue
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Fiddling with it shouldn’t cause any issues but in extreme cases, it can damage the connector, either on the screen end or the logic board. If you suspect you damaged it, then look at it under magnification to see. If the pins are physically damaged, then the connector has to be replaced (logic board) or the screen replaced depending on which connector end is damaged.
这个答案有帮助吗?
得分 1
1条评论:
I think I might’ve damaged the flex cable. I kept connecting and disconnecting due to getting a faulty housing. And my screen has alot of lines but when i put it in an odd position the screen works perfectly fine
完成的
添加一条评论
添加你的答案
kareemmohammed897 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 215
