跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
LCD damaged or more serious?
Put my 6s down while out walking/fishing and it started sliding off a rock. When I grabbed it quickly I think I must have jammed it against the rock and caused damage.
Screen had some weird lines on it initially bit they have gone now. No cracks to the top screen. LCD looks to have bled and the colour has a distinct blue hue to it on most of the screen.
Phone is generally playing up a little, ringer volume changing on its own. Rear camera not working, Flashlight not working. Asking Siri to turn on flashlight, give this reply that its already on. Asking turn it off, Siri says its already off!
Could this be all caused by a damaged LCD/digitizer or have is it time for a new phone?
Also, I can see a faint white line, like a crack in the top left corner. Its below the glass as the top screen is totally fine.
Cheers
Daniel
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I think you may be underestimating the force with which you “grabbed” it. Was the phone housing twisted, dented or damaged in any way or was a corner impacted? I’m also wondering about contact with water.
It certainly sounds like you have a damaged screen. You can replace that yourself by following this guide. As for the RCAM/Flash, those two are somewhat interrelated. This phone may need to be looked at more closely. It’s certainly worth fixing.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Daniel Rees 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 129
