跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Problems After Screen Replacement
See video for details. It basically starts up with a bright white light and then turns into vertical lines. It also sometimes displays 5 lock screens vertically. I have already tried a soft reset, but it had no effect.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Do you still have the original screen in a somewhat working condition? If so, try the original screen and see if this problem persists. That way we can rule out the screen.
Update (10/07/2018)
@blewisgabriel Sounds like we have our problem solved! If you wish you can buy another replacement screen at the link below. Go ahead and mark this as correct for completion sake.
iPhone 4S Screen
Replace a screen compatible with iPhone 4S. Includes all of the small parts pre-installed in the assembly, saving time and increasing the quality of your repair. 3.5 inch IPS LCD (640 x 960 pixel) Display.图片
产品
iPhone 4S Screen
$34.99
这个答案有帮助吗?
得分 0
5条评论:
I am working on that now...I will post an update.
完成的
@blewisgabriel Sounds like a plan! Keep us posted :-}
完成的
@ajcooke01 Well, I put the old screen back on and it works without a problem. I guess it is just a defective screen.
完成的
@ajcooke01 I tried putting the new screen back on and now the picture vibrates. Do you know anything about this?
完成的
@blewisgabriel You mean the phone won’t stop vibrating?
完成的
添加一条评论
If you still have the original LCD screen, put it back in and see if it does the same thing. It might be a defective / bad 3rd party screen you have there, or it has been damaged. A similar sort of white to gray vignette and vertical lines problem happened to my LG Optimus L90 - that is, after I put it through some physical stress tests.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Benjamin Gabriel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 118
