跳转到主内容
The HP Pavilion dv2000 Notebook PC is an entertainment based PC produced in 2007.
23 个问题 查看全部
screen was not switching ON
I facing different problem. In back round it was on, but screen was not switching ON.please tell something to solve this problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Hi @sree1810 ,
I've moved your comment to a new question as you have said that you have a different problem.
Please verify the make and model number of your laptop.
What OS is installed?
Has anything happened that you think may have caused the problem, e.g. laptop dropped, got wet, occurred after update etc.?
Try starting the laptop in "safe mode" to see if it works OK. Check online for how to start your particular Windows OS in safe mode as it varies slightly depending on OS (Win 7, 8.1 10) installed.
Any relevant information will help us to help you
完成的
添加一条评论
1个答案
Make sure that your screen cables are plugged in properly
Is your backlight on?
Try connecting to an external monitor
这个答案有帮助吗?
得分 0
1条评论:
My friend was just looking for this information. Thanks
完成的
添加一条评论
添加你的答案
Sreeganth 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 191
