跳转到主内容
HP Spectre x360 13-4101dx - 13.3" - Core i7 5500U - 8 GB RAM - 256 GB SSD
1 个问题 查看全部
HP Spectre X360 13-4101dx Motherboard DA0Y0DMBAF0 - What is this part?
I’ve got a hp Spectre X360 13-4101dx laptop with charging issue. I found that small thing on the motherboard (1st picture), and its original place probably(2nd picture).
Anybody can help me that what the name of it and its function? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
It’s a capacitor. Since they usually unmarked, and the one you have is broken in two, you cannot find out its original value. So you need first to find out the package by measuring the size (width and length, maybe height) and compare to a list of standard capacitor sizes. The size will constrain the voltage x capacity product (ie. for a given size, if you get a higher voltage one, it will have a lower capacity). Then you need to measure the voltage on the pins (most likely a standard voltage like 3.3, 5, 12, 24). Finally find the capacitor with the size you measured, the voltage rating directly above the one you measured (or one higher), and the highest capacity.
这个答案有帮助吗?
得分 0
添加一条评论
A little late, but that part is a surface-mount capacitor.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
voneout 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 1,159
