跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
iPhone 6 Plus Charges after Screen Replacement but doesnt turn on
Hey,
I replaced my iPhone 6 Plus Screen (Complete Screen= Camera, TouchID, Speaker alreadyinstallen on it). If i try to turn it on, the Apple logo shows up and than it`s Black but the Backlight is working. Than it shows the Logo that it’s charging. After couple minute the Apple Logo shows up and again the Backlight is working -> in a loop.
Hope someone can help me!
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
First of all, if you don’t transfer over the original Home Button, you will lose Touch ID functionality.
As for the problem at hand, I would re-install the original screen to see if the problem persists. If it does, then you may have damaged the logic board during the repair. If the old screen works fine, then you have an issue with the replacement screen. It’s not uncommon for screens that include the Front Camera/Sensor flex to have a defective part. Try not connecting the FCAM flex to see if that solves the problem. If it does, then transfer over your original flex along with the Home Button.
这个答案有帮助吗?
得分 3
2条评论:
Badly i cant see on the old screen becaus its damaged, it isn't black the LCD is broken. But i will buy an other screen an try it out.
完成的
Start by disconnecting the front camera flex to see if that will help.
完成的
添加一条评论
添加你的答案
Aruu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 41
