跳转到主内容
Second generation of the Ford Focus.
20 个问题 查看全部
Having trouble with a 2007 Ford Focus, what do I do?
Having trouble with a 2007 Ford Focus, getting spark fuel, everything just will not turn over
bumped the coil will not start.
the alarm light keeps flashing ran a tester wire is enabling through the alarm system everything is working but it will not turn over and start but it turns over when I bump the solenoid with the battery but will not start
what could it be tried the ignition switch key and key reader
I tried the ignition switch relay those were good and checked all fuses everything is all good but I think it has to do with the alarm on the car itself
what do I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I know this may seem like a stupid question, but did you check the starter itself? Also there are usually fuses and relays underneath the hood, did you also check those?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harvie Oconnor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 113
