跳转到主内容
Guides and support for various television (TV) brands and styles.
9064 个问题 查看全部
Repair service manual needed Toshiba 40L3453DB smart tv with built in
I desperately need a service repair manual for the Toshiba 40L3453DB I have tried google but can`t find one .Mostly i need to know the output voltage from psu to led`s as this tv has 5 rows in each has 9 led`s.I have fitted a Brand new psu and it shows 78.8v at the output to led`s but the lights will not light up .I have checked each light individually and all shows light one at a time .Please help,Thankyou
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
any body please help me
完成的
添加一条评论
1个答案
Replace the Main Board the power supply is not getting the 5V panel on voltage from the Main Board..
这个答案有帮助吗?
得分 0
1条评论:
This could be because of a bad solder joints on BGA microprocessor which is not getting good connections BGA is Ball Grid Array a technique Manufactures use to solder chips on boards. Little balls of solder pads underneath the chips.
完成的
添加一条评论
添加你的答案
moggy01 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 236
