跳转到主内容
The ATI Radeon X1900 XTX is a high-end graphics card from 2006.
How to repair a deadly graphics card
How to repair deadly graphics card
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi Anmol tech
what do you mean? when you connect, what do you observe when you test the graphic card....
artifacts?
no display?
完成的
添加一条评论
1个答案
已选择的解决方案
You don’t say what’s wrong with it or what you have tried. Is its presence recognised by Windows? Was it previously working but then failed, or is it one you’re trying to install? Does it work in a different machine? If it’s recognised, check for any available driver updates. Is your power supply sufficiently powerful to drive it?
Make sure the fan isn’t clogged with dust and is spinning freely when the card is powered up. Check that the gold fingers on the connector are clean an undamaged, and similarly the socket it plugs into. If it’s actually faulty then there’s probably not much in it which is repairable, realistically speaking.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Anmol tech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 537
