跳转到主内容
Released December 3, 1994 in Japan and September 9, 1995 in North America. Models SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
73 个问题 查看全部
The pause menu repeatedly keeps coming up
I have an old Playstation1 and when I was playing Gran Turismo on it the pause menu came up even though I didn’t press the start button, and no matter how many times I press continue the same thing happened again and again. I know there is no problem with the disc seeing as I was experiencing the same thing with Hydro Tunder. I’ve already tried resetting and turning it on and off
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
It’s probably a problem with the controller seeing as the Analog isn’t working and I didn’t have the issue with my second controller
完成的
添加一条评论
1个答案
最有帮助的答案
You might want to try a new controller and see if the issue persists there. Try a different controller and see if this behavior continues.
这个答案有帮助吗?
得分 1
1条评论:
I agree. The controller might be suffering from a sticky button, and that's usually due to dirt buildup, grime, and possibly food causing the button to stick. A temporary solution is to gently pull the button back out, but the best thing to do is take the controller apart and clean it. Sometimes the membrane pads will lose their strength, causing the 'spring' to cease functioning. If that happens, the membrane pads need to be replaced, or the remote needs to be replaced.
完成的
添加一条评论
添加你的答案
AdamsMatthew 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 48
