跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
3GS front panel and screen fallen out with screws still in
I have recently found my own old 3GS I tried charging and the apple logo appeared and went off numerously over many hours never powering on I assume it will need a new battery later the entire LCD started falling out from the top and the entire screen came out but the screws were left in. do all replacement screens come with new screw attachments and how can I keep the screen in if not.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You can buy replacement screws from here, no need to buy a new screen if the old one works fine. ;-)
Update (09/26/2018)
@jbb25 Tesa tape is a wonderful adhesive. I believe that 2 mm Test tape would work great for this purpose as it is very strong. Just use as much as you can to hold the screen down without going over electronics or circuit boards.
Tesa 61395 Tape
Tesa 61395 Tape图片
产品
Tesa 61395 Tape
$5.99
这个答案有帮助吗?
得分 0
3条评论:
Thank you but some of the screw brackets are still in the phone rather than the screen could I screw them out and glue with fast drying super glue back on.
完成的
@jbb25 Ohh, sorry about that! I thought you needed screws. Sadly, iFixit does not sell a replacement screen so I cannot confirm or advise against what your idea is. I am skunked!
完成的
Thanks for your help anyway Aaron Ive just checked eBay and found a few adhesives hopefully I can reattach the brackets and refit the screen back in after the new batterie has gone in.
完成的
添加一条评论
添加你的答案
Joshua Borthorpe Bain 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 43
