跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Vertical lines on screen
I was trying to set some adhesive on the screen to keep it in place (as the pentalobe screw sockets snapped off), and I followed the guide which said to heat up the phone with a hair dryer until it was too hot to touch. I then turned on the phone and got a temperature warning. After that, the screen went all pixellated, and had vertical lines going down across it with a bluish tint to all colour on the display. I tried a good known screen, and that was fine. Is there any way to fix this, or do I have to replace the screen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sounds like you may have cooked the display or somehow damaged the ribbon cable, maybe with too much heat. Would suggest the only option is to replace the screen. I am sure you have tried re-seating the screen cables?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Albert Einstein 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 11
总计 108
