跳转到主内容
2016年版Retina MacBook的更新版本。型号A1534,EMC 3099。现在采用更快的Kaby Lake处理器,最高可达1.4 GHz Core i7,支持Turbo Boost加速至3.6 GHz,SSD速度提升高达50%,并支持高达两倍的内存。
82 个问题 查看全部
Is deleted BootCamp partition recovery become possible macOS Sierra?
I have accidentally deleted bootcamp partition on my Mac computer using disk utility because windows 8 has been damaged or corrupted while I try to resetting it. Note that I wasn't using bootcamp assistant to install windows 8. I managed to make my drive into a single partition but when I press alt/option on boot, I still can see the windows boot option and the data stored in it. How to repair my Mac hard drive so the windows boot option disappear?
Please tell me any solution on how to restore the BootCamp partition data back to my Mac hard drive and regain access to it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
You can take the help of a Mac data recovery software that provides deleted or lost BootCamp partition recovery features. Also, avoid using the Mac machine to make sure that no other files gets over-written on that Mac hard drive.
这个答案有帮助吗?
得分 2
添加一条评论
Sorry to say its not recoverable ;-{
When you deleted FAT32/exFAT partition and make it part of your GUID partition that did you in. A BootCamp install is a bit different than a raw Windows install which is what you did here. A BootCamp install creates a special folder to hold Windows environment in a VM space. A raw install is when you treat the Mac system as if it where a Dell/HP laptop but you made an isolated partition to run Windows vs MacOS.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
James Rough 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 916
