跳转到主内容
A general-purpose audio device that transmits low audio frequencies to your ears.
22 个问题 查看全部
What is this burned piece called
Punched my subwoofer cuz it wasnt working. I think it had blown voice coil. Semi worked then a few days later my stock amplifier from my 08 Mitsubishi lancer gts started smoking from under my seat. I took it out and opened it to find this. Can i take this piece out and fix it with a new one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Brian .... that is the power amplifier IC
are you good in soldering, for this .... If you have a hot air…. desolder it, note the part no and order replacement.
some idea for you to read……
e.g. troubleshoot, inspect, etc.
http://jestineyong.com/two-ics-burnt-in-...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Brian Mcqueen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 66
