跳转到主内容
加入维修社区 - 创建账户
关于型号为 500-c60 且型号代码为 F3D80AA 的 HP Pavilion 台式机的维修信息与故障排除指南。这款台式塔式机于 2013 年首次生产。
Why isnt my computer booting?
My desktop booted just fine to the desktop, i opened a folder, and left for like 30 minutes to make dinner. i came back to a black screen, and assumed it was in sleep mode. wiggling the mouse and pressing buttons on the keyboard wouldn’t wake it up, so i tried turning it off. the power button wouldn’t work. i unplugged the pc (it has an external psu, a connector plugs right into the motherboard). when i plugged it back in, it wont post, and there is no usb power. the light in the power button is off, but a green motherboard led is on and the fans spin. things ive tried: using the bios reset jumper, taking out cmos battery for 5 minutes and reseating it, reseating ram, unplugging all devices from usb and motherboard connectors. nothing worked. any help?
Edit: i also tried unplugging it and completely draining the power by holding the power button
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论:
We need the model number of your computer, and Make.
Could possible help then.
完成的
HP Desktop pavilion 500-c60
完成的
添加一条评论
1个答案
Ok so just to try to narrow down the issue I have a couple questions that may seem random but I am trying to see if you are having a similar situation I had with my desktop pc.
  1. Are you using windows 10 and more specifically, did you reinstall windows recently?
  2. Does your pc require you logging in prior to booting to desktop?
As you seemingly did alot of troubleshooting prior to posting I don’t want to give you anything else unless it may fix it so your answers to the above would help.
这个答案有帮助吗?
得分 0
1条评论:
yes, no it wasnt recent, yes i need to log into windows, but not bios
完成的
添加一条评论
添加你的答案
Cameron Dus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 1,250
