跳转到主内容
Dot (.) and comma (,) not functioning on the keyboard. How to fix it?
All other keys except dot (.) and comma(,) are not functioning. I thought by formatting the laptop will solve the issue but I am stuck as I am unable to use (.) to put in my apple ID. I have erased it completely and was trying to reinstall the OSX 10.7 lion but don't know what to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Have you tried connecting an external USB keyboard?
完成的
添加一条评论
1个答案
Have you tried using an external keyboard?
If it works in the external keyboard, the mechanism below the keys are most likely defect, which is fixed by replacing the entire keyboard. This is quite a time extensive and difficult repair. But if done carefully, it is doable.
What might be another solution you can try since the keys aren’t working: you can take the keycap of the keyboard, by sticking something like a guitar pick under the key (check google/ifixit to see how to). Cleaning it and trying to press the mechanism without the key, will show you if the keyboard underneath the keys is defect or not.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
milind 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 60
总计 1,974
