跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
SSD upgrade 2018 model
Hello,
Is it possible to upgrade the SSD in the latest MacBook Air (2018) model, or has Apple soldered it making this impossible?
Thanks…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
There is no 2018 model as of yet. The most current model is the Early 2017 13"
完成的
Thanks Dan!
From what I understand from the demo below, a 2017 13"'s SSD should be replaceable; do you agree?
Thanks...
完成的
Yes you can replace it with either the OWC SSD or the custom Apple SSD designed for your system.
完成的
添加一条评论
1个答案
最有帮助的答案
The 2017 model uses the exact same design as the 2015 model. The only difference was an upgraded CPU chip as Intel stopped producing the chip Apple was using.
Here’s the IFIXIT guide you’ll need to follow: MacBook Air 13" Early 2015 SSD更换 and here’s the needed SSD [关联产品丢失或禁用: IF123-123]
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Dav 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 3,827
