跳转到主内容
The 2013 revamp of the desktop Mac series known as the Mac Pro.
Extremely loud beeping on startup
I was going thru my tech teacher’s back room today and I came across a 2014 Mac Pro. I plugged it in hoping I would have found a hidden gem, but with my luck I got no dice.
As soon as I pressed the power button, there were 5 extremely loud beeps at least 1 second apart that almost made me jump. I unplugged it immediately, and tried again. 5 beeps. I tried the SMC, PRAM and NVRAM resets which all were to no avail.
TL;DR: 5 extremely loud beeps on startup each at least 1 second apart. Tried all the resets. Help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Here’s another reference: Macintosh Beep Codes
See if you can recover the EFI and SMC firmware using these:
这个答案有帮助吗?
得分 2
6条评论:
@danj I cannot boot up the machine is therefore I can’t try those two things you mentioned. Replacing the CPU is just simply too expensive, so I think this machine is a brick. Thanks for your helpful input!
完成的
It still might be possible!There is a special tool you can use to access the service connector on the base to recover the firmware. I'll need to find it when I go home for lunch.
完成的
@ajcooke01 - Here's the info MattCard You'll need to ask for his beta card for the Mac Pro
完成的
@danj I think I am going to just call it done. There is water damage to the Logic Board that I just discovered now that is beyond repair. I think I’ll gut it and use it as a ruler holder ;)
完成的
Gee! Such a waste ;-{ Even if you got the four core Xeon logic board it's a great system! That's what I use for photo editing.
完成的
显示更多的1条评论
添加一条评论
最有帮助的答案
1 beep = no RAM installed
2 beeps = incompatible RAM types
3 beeps = no good banks
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
5 beeps = processor is not usable
From what I could find digging through i fix it
MacBook 5 Beep Sound not booting up..
这个答案有帮助吗?
得分 3
2条评论:
Yep, CPU board may need to be replaced.
完成的
@ambientprotect Thank you for your imput! I upvoted your answer to be fair too.
完成的
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 1,929
