Why is my driver’s side window not going up when the controll is pre
Power window does not respond when control pressed on driver’s window. It is stuck in the down position. All other windows work ok. Lock button is in the off position .
Hey, Robert. This could be one of 2 issues. Either the switch itself or the window motor. You’ll need to remove the switch and use a multimeter to test the switch. If the switch is not your problem it is probably the motor. Here’s a video of someone taking their passenger door panel off of a ‘06 Xterra, It should be very similar to yours. Good luck and let us know how it goes!
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 1,499
