跳转到主内容
加入维修社区 - 创建账户
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
I can't separate the screen from the device without destroying the lcd
I’m using heat and prying the screen out of the phone with the special very thin metal sheet and I am halfway through but tested the screen and 70% of the screen is completely black and dead. This lcd was already trash and I’m trying to salvage another s7 edge’s screen, but I can’t even take it off without destroying it. Please help! I am so frustrated, I cannot take it off and still have it work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
These displays are obnoxiously hard to get off, I have tried this too and I completely wrecked the display. My suggestion is to just buy a new display as these displays are next to impossible to get off in one piece.
完成的
Yea dont even bother honestly. They are the worst. Aaron is 100% correct. Just replace the LCD assembly
完成的
添加一条评论
2个答案
最有帮助的答案
Why is the LCD being separated from a frame? You just simply transfer the logic boards over instead, unless the parts are incompatible after testing them?
这个答案有帮助吗?
得分 2
1条评论:
I'm trying to do glass replacement only. I need to take it off anyway.
完成的
添加一条评论
After conferring with some of my friends who have done this similar repair I have come to the conclusion that it is just better off if you get a new display assembly and slap that on instead of trying to do a next-to-impossible screen transfer. That way you can hack away at that old display and just slap on a new one with no consequences. iFixit sells a display assembly for this phone too and I have provided a link below to that part.
Tl;DR: Just buy a new display assembly because these displays are impossible to get off in one piece.
Galaxy S7 Edge Screen
The “fix kit” is out of stock but you can buy just the assembly and nothing else.
Replace a screen compatible with the Samsung Galaxy S7 Edge model smartphone. 5.5 inch (140 mm) AMOLED 2560 × 1440 display and Front Glass Digitizer.图片
产品
$159.99
这个答案有帮助吗?
得分 1
4条评论:
Yeah glass only replacement never leaves a good finish unless you use the proper refurbishing machinery to do it properly.
完成的
@benjamen50 I think just replacing the whole assembly is just a better option because it saves frustration and time.
完成的
Thanks, but I'm not gonna spend $300. Also it doesn't answer my question, I didn't ask for alternatives. I am fully aware that this is very very challenging, you don't need to tell me that.
完成的
@gracetheartist I have no solution for you then. Good luck hacking away at that display then. You can try using a hair dryer to soften the adhesive but that’s all.
完成的
添加一条评论
添加你的答案
gracetheartist 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 92
