跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
IOS 12 touch issues
Hi ya’ll!
So, it seems apple is still at it, with making our lives hard. I've recently experienced iphone 7 plus aftermarket screens, where the touch stopped working directly after an update to ios 12. I haven't had that confirmed yet - have any of you experienced the same?
If so, I think it's the same issue as on ip6s a while ago, and also ip8. Make sure to use screens with original IC, so it won't be an issue - at least until apple throws in a fix in an update, like the other times. They claim to have removed ALS issues, but there has been reports of issues still. Best bet is to keep moving screen data with ALS-BOX, to prevent issues.
Can anyone give me feedback here? Thanks in advance.
Update (09/25/2018)
So yeah, I've gotten the news from one of our suppliers - there is issues with IC’s of sub par quality, go for oem screens with original IC's, and all should be good..:) same as ip6s on ios 10 (i think it was), and ip8 on ios 11..:) will most likely be solved on update..:)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
5条评论
Hi Mikkel, that's an interesting observation! Wouldn't be surprised at all :(.
完成的
@Minho - yeah, it's a very apple-like-dick-move.. They pulled the same with 6s, I have a post about it here as well.. And supposedly also some types of oem 8/plus, along with the homebutton flex - so I wouldn't be surprised by this, but we'll see what people find out and..;)
完成的
Thanks for keeping us updated!
完成的
Yeah I had a feeling this was the case. I wonder when my supplier will catch on to it.
Already had a few iPhone 7s with this issue for aftermarket screens.
完成的
@benjamen50 it certainly can't be a coincidence that every major update brings the same issues.
完成的
添加一条评论
2个答案
最有帮助的答案
ive had this problem with a iphone 7 before just do a hard reset by holding down the power and home button until the apple logo comes on and once it boots you should be good
这个答案有帮助吗?
得分 1
1条评论:
I thought the same thing. However, I ‘ve done that already. Several times. It makes minimal difference. Thinking about replacing the touch part if the screen. Will also allow me to upgrade battery. It’s at 82% and charges fast but battery life is like a newborn mouse in a mongoose nest filled with a striving family.
Is it possible that the few (cough cough) times I have dropped it, the mechanical part of the touch alignment mechanism unaligned. Or do I just have weird under powered finger tips. All joking aside, I wonder if that is a real medical condition?
Sincerely with thanks,
Keith A. Istre
完成的
添加一条评论
Dear Passive/Agressive Conrads of Lord Apple and It’s innovation,
Have similar issues. What are the symptoms?
My list includes;
  1. Screen corners not reacting (like where the system back bottoms are usually). The corners back bottom will not react while I can still scroll the page.
  2. Also, I had to turn 3D Touch off because a touch harder than the first degree would get both the second and third pressure option at the same time.
  3. Finally (this may just me, my wide fingertips, getting old, are just doing it wrong),I can not seem to touch the correct intended pixels. This is especially bad the keyboard.
Thanks y’all for the support.
Sincerely,
Keith Istre
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mikkel Øgendahl 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 525
