跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Replaced Battery, % Now Inconsistent, Coconut Batt says "Failure- yes"
I replaced the swollen OEM battery in my MBP 2012 with one from ifixit. However, since doing so, the few times I’ve had to use it away from a power source, the battery percentage drops immediately from 100% to 94% and then falls quickly until the MBP goes into hibernation at around 40% - I might get slightly over 2 hours use out of it.
I’ve tried the SMC reset listed here: https://ifixit-eu-en.helpscoutdocs.com/a.... No joy.
I’ve installed and run Coconut Battery, which says “Battery Failure - Yes” amongst other things (I will try to attach the screenshot)
Is there anything I can do? Or do I have a dud battery and need to replace it again?
Thanks,
David
Update (09/21/2018)
Coconut battery screenshot:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You’ll need to get a replacement battery. There appears to be a problem with it. Look at your paperwork for the return instructions.
这个答案有帮助吗?
得分 1
1条评论:
Thank you - I will do that!
完成的
添加一条评论
添加你的答案
David Fardon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 173
