跳转到主内容
加入维修社区 - 创建账户
Released on June 23, 1996, Model NUS-001, the N64 is Nintendo's first, and, up until the release of the Switch, only 64-bit gaming console (The GameCube, Wii, and Wii U could perform 64-bit floating-point calculations, but this is not true 64-bit architecture).
The side of my cartridge slot is coming off, how do I fix it?
is it really needed? And how can I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Are you able to elaborate on the issue? Is the plastic part which houses the cartridge broken or is it the actual port itself?
完成的
添加一条评论
2个答案
最有帮助的答案
If it’s just the plastic, it shouldn’t really matter.. The cartridges work with or without the cover anyways.. For aesthetic purposes only, it’s up to you if you want to attempt a repair.
这个答案有帮助吗?
得分 1
添加一条评论
If I were you I may be tempted to plug the area that is crumbling with some tac and then just take care when removing or inserting cartridge.  I imagine its only use is to align the cartridge
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gideon Galley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 29
总计 327
