跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
High Battery charge quick drain
The battery in this phone was not lasting even a full day. I’ve successfully replaced the battery with an iFixit replacement. Other posts I’ve seen say that it needs to be “conditioned” - charging to 100%, Restarting the phone with power and Home button pressed until Apple Logo shows. I’ve done this twice now and the phone still shuts off overnight from being 100% charged at 2:00pm.
The local repair shop won’t touch it saying the battery is probably damaged and the charging circuit AND the battery would have to be changed out.
Any ideas please?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Even though you’re battery is “new”, you may have received a bad battery. Use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows). Anything less than 70% of design capacity will require replacement. You can also use the Battery Health Diagnostic (Settings\Battery\Battery Health (Beta)) in iOS 11.3 and above. It will tell you what the health of the battery is.
The problem with aftermarket batteries is that they don’t all report true numbers. iFixit takes great care in sourcing good batteries but a bad one is bound to slip through every once in awhile. So even if it tests properly, ideally, you need to test a known good battery to determine if the problem is with the battery or something else on the phone.
这个答案有帮助吗?
得分 1
添加一条评论
get a new battery for it
这个答案有帮助吗?
得分 0
1条评论:
"I've successfully replaced the battery with an iFixit replacement"
完成的
添加一条评论
添加你的答案
Chipp Frame 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 86
