跳转到主内容
A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 Processor. Released October 13, 2015.
93 个问题 查看全部
Boot problems, strange diagnostic leds.
My 2015 EMC2833 gave up on me and I don’t have a clue what it could be.
Are there any schematics available for this model? MB nr. 820-00431-A I have googled for a long time with no success.
I have removed the LCD to access the diagnostic leds.
When I connect power, both LED 1 and 2 lights up within 3 secs without me pressing the power button. if I push the power button the leds turn off and comes right back on again 2 seconds later.
But if I hold the power-button while inserting the power cable only led 1 lights up.
If I then release and push the power-button again led 2 lights up but no chime or fan-spin.
If I then hold the power for 6 seconds led 2 goes off and 1 stays on.
Why is there a difference if I hold power-button or not when inserting powercord?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
My computer don’t power up could be the problem. Maybe power supply
完成的
添加一条评论
1个答案
最有帮助的答案
These are the symptoms of a blow power supply. Here’s the IFIXT guide you’ll need to follow iMac Intel 21.5" Retina 4K Display Power Supply Replacement and the needed part iMac Intel 21.5" (Late 2012-2019) Power Supply.
You may want to check your electrical outlet to make sure its grounded and the breaker panel ground connection is in good shape as well.
You might want to get a good surge suppressor or better yet a UPS as often a power disruptions or lightning kill the power supplies.
iMac Intel 21.5" (Late 2012-2019) Power Supply图片
产品
$129.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kim Fossdal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 227
