跳转到主内容
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
369 个问题 查看全部
My S7 Edge cannot vibrate after opening up just the back
Hi, I've removed the back glass and the flat plastic puzzle like pieces right under it (like wireless charger, etc.) and now when I turn on the phone it cannot vibrate at all. I go to the testing menu by dialing the code and test the vibration part and nothing happens, absolutely no movement. What did I break? I simply removed the back, screws and plastic flat pieces. Those aren't the vibrating motor??? I didn’t touch anything else, no motherboard, no camera, no nothing.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Are you testing the device with the back piece screwed on? If not, then that may just be the issue. The black plastic piece holds and pushes the board slightly, and that would make the board have contact with the vibe motor (vibe motor has 2 gold contacts that need to make contact with the board). Turn off the device, screw the top plate on and see if it works.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
gracetheartist 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 37
