跳转到主内容
Why is my device not charging?
When my table is plugged into its charger, it shows a lightning bolt to show that its charging, and starts to boot up, then shuts off. This happens in nonstop cycles, each booting for about 5 seconds, then shutting off. Can I get some help? And it never actually gets charging, like no juice.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
you may have a faulty battery, how long have you had
这个答案有帮助吗?
得分 0
2条评论:
Ummm maybe 3-4 years
完成的
yeh, the battery is most likely dead/ dying id say either replace it or get it replaced
完成的
添加一条评论
Firstly, you need to ensure that you are using a working charger - not a faulty one that must be held in a specific position to work. If the charger is fine, check your battery as that could be the next faulty thing. Try replacing the battery. If the issue disappears, it was the battery, however, if the issue persists after changing the battery then it must be something more serious. I would recommend that you then take it to your supplier who will run diagnostics and/or open the device to find the root of the problem.
Hope this Helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Doe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 116
