跳转到主内容
Stuck at looking for updates
Hi all I have a LG g3 vista love that phone its rooted one day it started acting goofy so I shut it off the next day I turn it on and its at the safe start or factory reset spot you can just continue they're also that's what I did didn't get anywhere so I tried safe mode didn't help so I did a factory reset bingo so I thought now it goes as far as to looking for software update that's it awesome phone would love to get it back..as a side note its not used as a cell phone its only for streaming to tv or I have a few things I stream to and I use it for internet so there ya go please let me know if you Think you might have the answer to fix Thanks…I don't have much if any access to a computer other then my tablet Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Thanks but no that's not it I've been using them booting or trying to boot it functions fine tell it gets to search for updates the twrp isn't visible and it should be
just says modified I thought it should have at spot in the safe start area that I can click on to get into TWRP but it's not showing
完成的
添加一条评论
1个答案
check to make sure none of the buttons are stuck in place, volume, power etc. Could cause failed boot same way a lot of pcs or laptops won’t boot if you keep a key pressed down.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
im4ustgump 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 6
总计 31
