跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
Why is my iPhone stuck in a boot loop after screen replacement
This question hasn three parts:Okay….so after buying my step sister a new phone screen and installing it my self the logic board sparked, but before it sparked it was stuck in an infinite boot loop, any answers
second part: after the replacement the screen has lines going down the screen, any answers
third part: when I tried to fix the first and second part, I conneced the phone to iTunes and put it into recovery mode, but when I hit restore and let it restore the phone to factory settings, the phone was still experiencing the issues in the first and second, forgot to mention that when I installed a new home button, the new home button didn’t work…any answers
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Iphone 7 and new ios device have the new parody that The original home button that present on the phone at first is the solution for long boot loop.Check out if the problem of home button flex phone boot up after 5-6 minutes and working fine or Audio Ic problem.If the short bootloops that is the problem of baseband chip or bbpmu.
Any way changing home button is not the solution for that.
这个答案有帮助吗?
得分 0
1条评论:
So...are you saying I should buy a new home button bracket and a genuine apple home button
完成的
添加一条评论
Well, the screen may just be a non-quality part so I would advise you to return the screen and buy the screen from iFixit instead. iFixit only sources parts from trusted vendors who produce higher quality parts and iFixit also rigorously tests their parts too so there is less of a chance of part failure.
If the Logic Board did spark, you probably fried the Logic Board. I would give a new Logic Board a try and see if the boot loop goes away.
iPhone 8 Screen from iFixit
iPhone 8 Screen图片
产品
iPhone 8 Screen
$54.99
这个答案有帮助吗?
得分 0
2条评论:
Do you know where I can buy a genuine apple screen other than ifixit (to expensive from ifixit)
完成的
@seanmoss I do not recommend anywhere else because the "cheaper parts" tend to be either the scams or the defective ones. As of right now I do not know anywhere else I can get you a quality screen replacement for less money.
完成的
添加一条评论
Hello, I disconnect the front proximity sensor, the only downfall is that you lose the selfie camera function, but I would rather that, than no phone at all.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sean moss 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 1,370
