跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
iPhone doesn't wake up from standby
Hey, my iPhone 6 doesn’t wake up when it’s on standby. If I press the home button or standby button the backlight is enabled but the screen stays black. I forced a hard reset by using dfu-mode and tried different batteries and displays, but it still stays the same.
Do you have any additional ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Does your display ever work, like when you boot it from a shutdown; or is it always showing the backlight but no image when it should be “on”?
Try connecting it to 3uTools (for Windows) when the display isn’t working to see if the phone is fully (or still) booted. If 3uTools sees the phone, then you probably have a LCD driver issue. This requires a micro-soldering repair.
这个答案有帮助吗?
得分 1
1条评论:
Yes when I boot it it shows me an image. Everything is fine then. I turn it into standby and after 5 minutes or so it won't wake up.
完成的
添加一条评论
Most likely it is a broken LCD. The backlight turning on with no image means that the connections between the cable and the LCD at the top of the screen under the front camera flex has been broken. This can be fixed by replacing the screen
这个答案有帮助吗?
得分 0
1条评论:
I tried 4 displays. Problem stays.
完成的
添加一条评论
添加你的答案
elreparero 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 304
